REST API reference
Re-key the external key in the key hierarchy for an SVM
POST /security/gcp-kms/{gcp_kms.uuid}/rekey-external
Introduced In: 9.11
Rekeys the external key in the key hierarchy for an SVM with a Google Cloud KMS configuration.
Required properties
  • key_name - Google Cloud KMS key name.
Optional properties
  • project_id - Google Cloud KMS project ID.
  • key_ring_location - Google Cloud KMS key ring location.
  • key_ring_name - Google Cloud KMS key ring name.
  • security key-manager external gcp rekey-external
gcp_kms.uuid
string
path
True
UUID of the existing Google Cloud KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
key_name
string
key_ring_location
string
key_ring_name
string
project_id
string
Example request
  "key_name": "cryptokey1",
  "key_ring_location": "location1",
  "key_ring_name": "keyring1",
  "project_id": "project1"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
65537556
ONTAP is not able to successfully encrypt or decrypt because the configured external key manager for this SVM is in a blocked state. Possible reasons for a blocked state include the top-level external key protection key not found, disabled or having insufficient privileges.
65537610
Rekey cannot be performed on the SVM while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent rekeying for the SVM. Use the REST API PATCH method "/api/security/key-stores/{uuid}" to re-run and complete the operation.
65537721
Google Cloud KMS is not configured for the given SVM.
65537729
External rekey failed on one or more nodes. Use the REST API POST method "/api/security/gcp-kms/{uuid}/rekey-external" to try the rekey operation again.
65537753
The "key_name" value contains invalid characters. A forward slash '/' is not allowed in the key name.
65537755
Google Cloud KMS configuration details were not found for the SVM.
65539436
Rekey cannot be performed on the SVM while the enabled keystore configuration is being initialized. Wait until the keystore is in the active state, and rerun the rekey operation.
65539437
Rekey cannot be performed on the SVM while the enabled keystore configuration is being disabled.
gcp_kms_key
key_name
string
key_ring_location
string
key_ring_name
string
project_id
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
