REST API reference
Creates an svm peer permission
  • cluster_peeruuid or cluster_peername - peer cluster name or peer cluster uuid
  • applications - peering applications # related ontap commands
  • vserver peer permission create # examples the following examples show how to create svm peer permissions <br/> 1 creates an svm peer permission entry with the local svm and cluster peer names <br/> ` post "/api/svm/peer-permissions" {"cluster_peer":{"name":"cluster2"}, "svm":{"name":"vs1"}, "applications":["snapmirror"]} ` <br/> 2 creates an svm peer permission entry with the local svm and cluster peer uuid <br/> ` post "/api/svm/peer-permissions" {"cluster_peer":{"uuid":"d3268a74-ee76-11e8-a9bb-005056ac6dc9"}, "svm":{"uuid":"8f467b93-f2f1-11e8-9027-005056ac81fc"}, "applications":["snapmirror"]} ` <br/> 3 creates an svm peer permission entry with all svms and the cluster peer name <br/> ` post "/api/svm/peer-permissions" {"cluster_peer":{"name":"cluster2"}, "svm":{"name":"*"}, "applications":["snapmirror"]} ` <br/> # learn more
  • [doc /svm/peer-permissions](#docs-svm-svm_peer-permissions)
POST /svm/peer-permissions
Introduced In: 9.6
Creates an SVM peer permission.
Required properties
  • svm.name or svm.uuid - SVM name
  • cluster_peer.uuid or cluster_peer.name - Peer cluster name or peer cluster UUID
  • applications - Peering applications
The following examples show how to create SVM peer permissions.
  1. Creates an SVM peer permission entry with the local SVM and cluster peer names
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"VS1"}, "applications":["snapmirror"]}'
  1. Creates an SVM peer permission entry with the local SVM and cluster peer UUID
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"uuid":"d3268a74-ee76-11e8-a9bb-005056ac6dc9"}, "svm":{"uuid":"8f467b93-f2f1-11e8-9027-005056ac81fc"}, "applications":["snapmirror"]}'
  1. Creates an SVM peer permission entry with all SVMs and the cluster peer name
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"*"}, "applications":["snapmirror"]}'
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
applications
array[string]
A list of applications for an SVM peer relation.
cluster_peer
cluster_peer
Peer cluster details
svm
svm
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*".
Example request
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "svm": {
    "name": "svm1",
Status: 201, Created
applications
array[string]
cluster_peer
cluster_peer
svm
svm
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error codes Description
26345572
{field} is a required field.
26345573
Failed to find the SVM or volume UUID with name.
26345574
Failed to find the SVM or volume name with UUID.
26345575
The specified peer cluster name and peer cluster UUID do not match.
string
cluster_peer
name
string
uuid
string
svm
name
string
The name of the SVM.
uuid
string
svm_peer_permission
Manage SVM peer permissions.
applications
array[string]
cluster_peer
cluster_peer
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
