Create an SVM peer permission
Creates an SVM peer permission to establish communication settings between Storage Virtual Machines (SVMs) and their cluster peers. Use this endpoint when configuring peering applications such as SnapMirror for data replication workflows.
HTTP method and endpoint
POST /svm/peer-permissions
Introduced in
ONTAP 9.6
Required properties
svm.nameorsvm.uuid- SVM name -
cluster_peer.uuidorcluster_peer.name- Peer cluster name or peer cluster UUID -
applications- Peering applications
Related ONTAP commands
vserver peer permission create
The following examples show how to create SVM peer permissions.
Creates an SVM peer permission entry with the local SVM and cluster peer names
POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"VS1"}, "applications":["snapmirror"]}'
Creates an SVM peer permission entry with the local SVM and cluster peer UUID
POST "/api/svm/peer-permissions" '{"cluster_peer":{"uuid":"d3268a74-ee76-11e8-a9bb-005056ac6dc9"}, "svm":{"uuid":"8f467b93-f2f1-11e8-9027-005056ac81fc"}, "applications":["snapmirror"]}'
Creates an SVM peer permission entry with all SVMs and the cluster peer name
POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"*"}, "applications":["snapmirror"]}'
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
applications |
array[string] |
A list of applications for an SVM peer relation. |
cluster_peer |
Peer cluster details |
svm |
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*". |
Example request
"applications": [
"snapmirror",
"flexcache"
"cluster_peer": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
Status: 201, Created
applications |
array[string] |
cluster_peer |
svm |
"applications": [
"snapmirror",
"flexcache"
"cluster_peer": {
"name": "cluster2",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345572 |
{field} is a required field. |
26345573 |
Failed to find the SVM or volume UUID with name. |
26345574 |
Failed to find the SVM or volume name with UUID. |
26345575 |
The specified peer cluster name and peer cluster UUID do not match. |
href |
string |
_links
cluster_peer
name |
string |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
svm_peer_permission
Manage SVM peer permissions.
applications |
array[string] |
cluster_peer |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
