Create an SVM peer permission
POST /svm/peer-permissions
Introduced In: 9.6
Creates an SVM peer permission.
Required properties
svm.nameorsvm.uuid- SVM name -
cluster_peer.uuidorcluster_peer.name- Peer cluster name or peer cluster UUID -
applications- Peering applications
Related ONTAP commands
vserver peer permission create
The following examples show how to create SVM peer permissions.
Creates an SVM peer permission entry with the local SVM and cluster peer names
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"VS1"}, "applications":["snapmirror"]}'
Creates an SVM peer permission entry with the local SVM and cluster peer UUID
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"uuid":"d3268a74-ee76-11e8-a9bb-005056ac6dc9"}, "svm":{"uuid":"8f467b93-f2f1-11e8-9027-005056ac81fc"}, "applications":["snapmirror"]}'
Creates an SVM peer permission entry with all SVMs and the cluster peer name
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"*"}, "applications":["snapmirror"]}'
Learn more
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
applications  |
array[string]  |
A list of applications for an SVM peer relationship.  |
cluster_peer  |
Peer cluster details  |
svm  |
Local SVM permitted for peer relationship. To create peer permissions for all SVMs, specify the SVM name as "*".  |
Example request
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "svm": {
    "name": "svm1",
Status: 201, Created
applications  |
array[string]  |
cluster_peer  |
svm  |
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
  "svm": {
    "name": "svm1",
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345572  |
{field} is a required field.  |
26345573  |
Failed to find the SVM or volume UUID with name.  |
26345574  |
Failed to find the SVM or volume name with UUID.  |
26345575  |
The specified peer cluster name and peer cluster UUID do not match.  |
9896057  |
SVM peer permission already exists.  |
href  |
string  |
_links
cluster_peer
name  |
string  |
uuid  |
string  |
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
svm_peer_permission
Manage SVM peer permissions.
applications  |
array[string]  |
cluster_peer  |
svm  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
