REST API reference
Create an SVM peer permission
Creates an SVM peer permission to define the allowed interactions between storage virtual machines and peer clusters. Use this to manage secure and efficient data sharing across different clusters in your ONTAP environment.
HTTP method and endpoint
POST /svm/peer-permissions
Introduced in
ONTAP 9.6
Required properties
  • svm.name or svm.uuid - SVM name
  • cluster_peer.uuid or cluster_peer.name - Peer cluster name or peer cluster UUID
  • applications - Peering applications
  • vserver peer permission create
The following examples show how to create SVM peer permissions.
  1. Creates an SVM peer permission entry with the local SVM and cluster peer names
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"VS1"}, "applications":["snapmirror"]}'
  1. Creates an SVM peer permission entry with the local SVM and cluster peer UUID
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"uuid":"d3268a74-ee76-11e8-a9bb-005056ac6dc9"}, "svm":{"uuid":"8f467b93-f2f1-11e8-9027-005056ac81fc"}, "applications":["snapmirror"]}'
  1. Creates an SVM peer permission entry with all SVMs and the cluster peer name
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"*"}, "applications":["snapmirror"]}'
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
applications
array[string]
A list of applications for an SVM peer relationship.
cluster_peer
cluster_peer
Peer cluster details
svm
svm
Local SVM permitted for peer relationship. To create peer permissions for all SVMs, specify the SVM name as "*".
Example request
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "svm": {
    "name": "svm1",
Status: 201, Created
applications
array[string]
cluster_peer
cluster_peer
svm
svm
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
  "svm": {
    "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error codes Description
26345572
{field} is a required field.
26345573
Failed to find the SVM or volume UUID with name.
26345574
Failed to find the SVM or volume name with UUID.
26345575
The specified peer cluster name and peer cluster UUID do not match.
9896057
SVM peer permission already exists.
string
cluster_peer
name
string
uuid
string
svm
name
string
uuid
string
svm_peer_permission
Manage SVM peer permissions.
applications
array[string]
cluster_peer
cluster_peer
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
