Retrieve automatic update configuration
Query automatic update configurations using this API to retrieve details about all the current settings. This endpoint supports only GET calls to ensure you can access the latest configuration data efficiently.
Overview
Use this API to query and retrieve all the configurations for automatic updates.
This API only supports GET calls.
Retrieving the configuration settings for automatic updates
The following example shows how to retrieve settings for all automatic updates:
# The API:
GET /support/auto-update/configurations/
# The call:
curl -X GET "https://<mgmt-ip>/api/support/auto-update/configurations?fields=*"
# The response:
"records": [
"uuid": "440ae2e4-fd8f-4225-9bee-94e2da3f8d9d",
"category": "firmware",
"description": {
"message": "SP/BMC Firmware",
"code": "131072402"
"action": "confirm",
"num_records": 1
