REST API reference
Retrieve automatic update configuration
Query automatic update configurations to access all current settings for system updates. This API is designed for retrieving information through GET calls only.
Overview
Use this API to query and retrieve all the configurations for automatic updates.
This API only supports GET calls.
Retrieving the configuration settings for automatic updates
The following example shows how to retrieve settings for all automatic updates:
# The API:
GET /support/auto-update/configurations/
# The call:
curl -X GET "https://<mgmt-ip>/api/support/auto-update/configurations?fields=*"
# The response:
"records": [
    "uuid": "440ae2e4-fd8f-4225-9bee-94e2da3f8d9d",
    "category": "firmware",
    "description": {
      "message": "SP/BMC Firmware",
      "code": "131072402"
    "action": "confirm",
"num_records": 1
