Retrieve automatic update configuration
Query and retrieve configurations for automatic updates using this API to ensure your system is set to the latest standards.
Overview
Use this API to query and retrieve all the configurations for automatic updates.
This API only supports GET calls.
Retrieving the configuration settings for automatic updates
The following example shows how to retrieve settings for all automatic updates:
# The API:
GET /support/auto-update/configurations/
# The call:
curl -X GET "https://<mgmt-ip>/api/support/auto-update/configurations?fields=*"
# The response:
"records": [
"uuid": "440ae2e4-fd8f-4225-9bee-94e2da3f8d9d",
"category": "firmware",
"description": {
"message": "SP/BMC Firmware",
"code": "131072402"
"action": "confirm",
"num_records": 1
