Retrieve automatic update configuration
Retrieve configurations for automatic updates by using this API to query current settings. These endpoints support GET calls to ensure you have the latest update configuration details.
Overview
Use this API to query and retrieve all the configurations for automatic updates.
This API only supports GET calls.
Retrieving the configuration settings for automatic updates
The following example shows how to retrieve settings for all automatic updates:
# The API:
GET /support/auto-update/configurations/
# The call:
curl -X GET "https://<mgmt-ip>/api/support/auto-update/configurations?fields=*"
# The response:
"records": [
"uuid": "440ae2e4-fd8f-4225-9bee-94e2da3f8d9d",
"category": "firmware",
"description": {
"message": "SP/BMC Firmware",
"code": "131072402"
"action": "confirm",
"num_records": 1
