REST API reference
View CIFS connection information
Overview
ONTAP CIFS connections show functionality is used to display currently established CIFS connections.
Information on the CIFS connection
  • Retrieve the list of the established CIFS connections
Example
Retrieving established connection information
To retrieve the list of CIFS connections, use the following API.
# The API:
GET /protocols/cifs/conections
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/cifs/connections?return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
  "records": [
      "node": {
        "uuid": "85d46998-4e5d-11ea-afb1-0050568ec4e4",
        "name": "ganeshkr-vsim1"
      "svm": {
        "uuid": "fc824aa8-4e60-11ea-afb1-0050568ec4e4",
        "name": "vs1"
      "sessions": [
              identifier: 625718873227788312
      "identifier": 91842,
      "server_ip": "10.140.70.197",
      "client_ip": "10.74.7.182",
      "client_port": 12345,
      "network_context_id": 3
      "node": {
      "svm": {
         "name": "vs1"
      "sessions": [
            identifier: 625718873227788579
            identifier: 625718873227788577
      "identifier": 92080,
      "client_ip": "10.140.133.97",
      "client_port": 23413,
      "network_context_id": 5
  "num_records": 2
