View CIFS connection information
Access currently established CIFS connections using these endpoints to monitor active sessions within your ONTAP environment. Retrieve detailed information such as server and client IPs, session identifiers, and network context.
Overview
ONTAP CIFS connections show functionality is used to display currently established CIFS connections.
Information on the CIFS connection
Retrieve the list of the established CIFS connections
Example
Retrieving established connection information
To retrieve the list of CIFS connections, use the following API.
# The API:
GET /protocols/cifs/conections
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/cifs/connections?return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
"records": [
"node": {
"uuid": "85d46998-4e5d-11ea-afb1-0050568ec4e4",
"name": "ganeshkr-vsim1"
"svm": {
"uuid": "fc824aa8-4e60-11ea-afb1-0050568ec4e4",
"name": "vs1"
"sessions": [
identifier: 625718873227788312
"identifier": 91842,
"server_ip": "10.140.70.197",
"client_ip": "10.74.7.182",
"client_port": 12345,
"network_context_id": 3
"node": {
"svm": {
"name": "vs1"
"sessions": [
identifier: 625718873227788579
identifier: 625718873227788577
"identifier": 92080,
"client_ip": "10.140.133.97",
"client_port": 23413,
"network_context_id": 5
"num_records": 2
