View CIFS connection information
Access CIFS connection information endpoints to view details about currently established CIFS connections within your environment. Use these endpoints to retrieve lists of active connections, helping you monitor and manage network activities effectively.
Overview
ONTAP CIFS connections show functionality is used to display currently established CIFS connections.
Information on the CIFS connection
Retrieve the list of the established CIFS connections
Example
Retrieving established connection information
To retrieve the list of CIFS connections, use the following API.
# The API:
GET /protocols/cifs/conections
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/cifs/connections?return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
"records": [
"node": {
"uuid": "85d46998-4e5d-11ea-afb1-0050568ec4e4",
"name": "ganeshkr-vsim1"
"svm": {
"uuid": "fc824aa8-4e60-11ea-afb1-0050568ec4e4",
"name": "vs1"
"sessions": [
identifier: 625718873227788312
"identifier": 91842,
"server_ip": "10.140.70.197",
"client_ip": "10.74.7.182",
"client_port": 12345,
"network_context_id": 3
"node": {
"svm": {
"name": "vs1"
"sessions": [
identifier: 625718873227788579
identifier: 625718873227788577
"identifier": 92080,
"client_ip": "10.140.133.97",
"client_port": 23413,
"network_context_id": 5
"num_records": 2
