REST API reference
View CIFS connection information
Access CIFS connection information to view details about currently established CIFS sessions. Use these endpoints to monitor active connections for troubleshooting or auditing purposes.
Overview
ONTAP CIFS connections show functionality is used to display currently established CIFS connections.
Information on the CIFS connection
  • Retrieve the list of the established CIFS connections
Example
Retrieving established connection information
To retrieve the list of CIFS connections, use the following API.
# The API:
GET /protocols/cifs/connections
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/cifs/connections?return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
  "records": [
      "node": {
        "uuid": "85d46998-4e5d-11ea-afb1-0050568ec4e4",
        "name": "example_node_name"
      "svm": {
        "uuid": "fc824aa8-4e60-11ea-afb1-0050568ec4e4",
        "name": "vs1"
      "sessions": [
              identifier: 625718873227788312
      "identifier": 91842,
      "server_ip": "10.140.70.197",
      "client_ip": "10.74.7.182",
      "client_port": 12345,
      "network_context_id": 3
      "node": {
      "svm": {
         "name": "vs1"
      "sessions": [
            identifier: 625718873227788579
            identifier: 625718873227788577
      "identifier": 92080,
      "client_ip": "10.140.133.97",
      "client_port": 23413,
      "network_context_id": 5
  "num_records": 2
