Delete an IP subnet
Deletes an IP subnet to remove its configuration from the network setup. Use this endpoint when you need to reorganize or clear unused subnets from your system.
HTTP method and endpoint
DELETE /network/ip/subnets/{uuid}
Introduced in
ONTAP 9.11
Related ONTAP commands
network subnet delete
uuid |
string |
path |
True |
IP subnet UUID |
Status: 200, Ok
