Delete an IP subnet
DELETE /network/ip/subnets/{uuid}
Introduced In: 9.11
Deletes an IP subnet.
Related ONTAP commands
network subnet delete
uuid |
string |
path |
True |
IP subnet UUID |
Status: 200, Ok
Status: Default
Fill error codes below. ONTAP Error Response Codes
| Error Code | Description |
1377663 |
The specified IP address range of subnet in IPspace contains an address already in use by a LIF. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
