REST API reference
Delete an IP subnet
Deletes an IP subnet to remove network configurations that are no longer needed.
HTTP method and endpoint
DELETE /network/ip/subnets/{uuid}
Introduced in
ONTAP 9.11
  • network subnet delete
uuid
string
path
True
IP subnet UUID
Status: 200, Ok
Status: Default
Fill error codes below. ONTAP Error Response Codes
Error Code Description
1377663
The specified IP address range of subnet in IPspace contains an address already in use by a LIF.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
