REST API reference
Delete an IP subnet
Deletes an IP subnet when you need to remove it from the network configuration.
HTTP method and endpoint
DELETE /network/ip/subnets/{uuid}
Introduced in
ONTAP 9.11
  • network subnet delete
uuid
string
path
True
IP subnet UUID
Status: 200, Ok
Status: Default
Fill error codes below. ONTAP Error Response Codes
Error Code Description
1377663
The specified IP address range of subnet in IPspace contains an address already in use by a LIF.
