Close open files identified by SVM
Closes open files identified by the SVM, file, connection, and session identifiers. This operation is useful for managing file access and ensuring system stability.
HTTP method and endpoint
DELETE /protocols/cifs/session/files/{node.uuid}/{svm.uuid}/{identifier}/{connection.identifier}/{session.identifier}
Introduced in
ONTAP 9.11
Usage notes
Closes open files identified by svm.uuid, file.identifier, connection.identifier and session_id.
Learn more
node.uuid |
string |
path |
True |
Node UUID. |
identifier |
integer |
path |
True |
File ID
connection.identifier |
integer |
path |
True |
Connection ID |
session.identifier |
integer |
path |
True |
Session ID
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
