Close open files identified by SVM
Closes open files associated with a specific SVM, using identifiers such as file, connection, and session ID to target the files for closure.
HTTP method and endpoint
DELETE /protocols/cifs/session/files/{node.uuid}/{svm.uuid}/{identifier}/{connection.identifier}/{session.identifier}
Introduced in
ONTAP 9.11
Usage notes
Closes open files identified by svm.uuid, file.identifier, connection.identifier and session_id.
Related ONTAP commands
vserver cifs session file close
Learn more
node.uuid |
string |
path |
True |
Node UUID. |
identifier |
integer |
path |
True |
File ID
connection.identifier |
integer |
path |
True |
Connection ID |
session.identifier |
integer |
path |
True |
Session ID
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
