REST API reference
Close open files identified by SVM
DELETE /protocols/cifs/session/files/{node.uuid}/{svm.uuid}/{identifier}/{connection.identifier}/{session.identifier}
Introduced In: 9.11
Closes open files identified by svm.uuid, file.identifier, connection.identifier and session_id.
  • vserver cifs session file close
node.uuid
string
path
True
Node UUID.
identifier
integer
path
True
File ID
  • format: int64
integer
path
True
Connection ID
session.identifier
integer
path
True
Session ID
  • format: int64
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
