REST API reference
Close open files identified by SVM
Closes open files identified by specific session parameters, ensuring data integrity and freeing up resources associated with those files. This operation is useful when you need to manage file access and maintain system performance in a virtualized storage environment.
HTTP method and endpoint
DELETE /protocols/cifs/session/files/{node.uuid}/{svm.uuid}/{identifier}/{connection.identifier}/{session.identifier}
Introduced in
ONTAP 9.11
Usage notes
Closes open files identified by svm.uuid, file.identifier, connection.identifier and session_id.
node.uuid
string
path
True
Node UUID.
identifier
integer
path
True
File ID
  • format: int64
integer
path
True
Connection ID
session.identifier
integer
path
True
Session ID
  • format: int64
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
