Delete a qtree
Deletes a qtree, removing the specified directory structure and its contents from the storage system.
HTTP method and endpoint
DELETE /storage/qtrees/{volume.uuid}/{id}
Introduced in
ONTAP 9.6
Related ONTAP commands
qtree delete
volume.uuid |
string |
path |
True |
Volume UUID |
id |
string |
path |
True |
Qtree ID |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
918235 |
A volume with UUID was not found. |
5242925 |
The limit for the number of concurrent delete jobs has been reached. |
5242955 |
The UUID of the volume is required. |
5242957 |
Failed to delete qtree with ID in the volume and SVM. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
