REST API reference
Delete a qtree
Deletes a qtree when you need to remove it from the storage system.
HTTP method and endpoint
DELETE /storage/qtrees/{volume.uuid}/{id}
Introduced in
ONTAP 9.6
  • qtree delete
volume.uuid
string
path
True
Volume UUID
id
string
path
True
Qtree ID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
918235
A volume with UUID was not found.
5242955
The UUID of the volume is required.
5242957
Failed to delete qtree with ID in the volume and SVM.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
