Delete a qtree
DELETE /storage/qtrees/{volume.uuid}/{id}
Introduced In: 9.6
Deletes a qtree.
Related ONTAP commands
qtree delete
volume.uuid  |
string  |
path  |
True  |
Volume UUID  |
id  |
string  |
path  |
True  |
Qtree ID  |
return_timeout  |
integer  |
query  |
False  |
Status: 200, Ok
| Name | Type | Description |
job  |
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
917505  |
Vserver not found.  |
917506  |
Volume not found.  |
917525  |
The specified volume does not exist in Vserver.  |
918235  |
A volume with UUID was not found.  |
5242894  |
The default qtree cannot be deleted.  |
5242895  |
Failed to delete the qtree.  |
5242897  |
This operation is not permitted on read-only volume.  |
5242898  |
This operation is only permitted on a data Vserver.  |
5242916  |
Cannot delete qtree because the volume contains one or more LUNs.  |
5242925  |
The limit for the number of concurrent delete jobs has been reached.  |
5242927  |
Unable to find qtree.  |
5242955  |
The UUID of the volume is required.  |
5242957  |
Failed to delete qtree with ID in the volume and SVM.  |
5242965  |
Invalid qtree path. The volume name component of the qtree path, must be the same as the volume specified with the parameter.  |
10485796  |
Cannot delete qtree because it contains a Storage Level Access Guard (SLAG).  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
job_link
_links  |
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
