REST API reference
Delete a qtree
DELETE /storage/qtrees/{volume.uuid}/{id}
Introduced In: 9.6
Deletes a qtree.
  • qtree delete
volume.uuid
string
path
True
Volume UUID
id
string
path
True
Qtree ID
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
917505
Vserver not found.
917506
Volume not found.
917525
The specified volume does not exist in Vserver.
918235
A volume with UUID was not found.
5242894
The default qtree cannot be deleted.
5242895
Failed to delete the qtree.
5242897
This operation is not permitted on read-only volume.
5242898
This operation is only permitted on a data Vserver.
5242916
Cannot delete qtree because the volume contains one or more LUNs.
5242925
The limit for the number of concurrent delete jobs has been reached.
5242927
Unable to find qtree.
5242955
The UUID of the volume is required.
5242957
Failed to delete qtree with ID in the volume and SVM.
5242965
Invalid qtree path. The volume name component of the qtree path, must be the same as the volume specified with the parameter.
10485796
Cannot delete qtree because it contains a Storage Level Access Guard (SLAG).
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
