REST API reference
Cancel the ongoing legal-hold operation
Cancels an ongoing legal-hold operation to stop the process before it completes. This is useful when you need to halt the operation without rolling back changes, helping you manage legal holds effectively.
HTTP method and endpoint
DELETE /storage/snaplock/litigations/{litigation.id}/operations/{id}
Introduced in
ONTAP 9.7
Usage notes
Aborts the ongoing legal-hold operation. An abort does not rollback any changes already made. You must re-run begin or end for cleanup.
  • snaplock legal-hold abort
Example
DELETE "/api/storage/snaplock/litigations/f8a67b60-4461-11e9-b327-0050568ebef5:l1/operations/16908292"
litigation.id
string
path
True
Litigation ID
id
string
path
True
Operation ID.
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
14090346
Internal Error. Wait a few minutes, then try the command again
14090541
A completed or failed operation cannot be aborted
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
