REST API reference
Cancel the ongoing legal-hold operation
DELETE /storage/snaplock/litigations/{litigation.id}/operations/{id}
Introduced In: 9.7
Aborts the ongoing legal-hold operation. An abort does not rollback any changes already made. You must re-run begin or end for cleanup.
  • snaplock legal-hold abort
Example
DELETE "/api/storage/snaplock/litigations/f8a67b60-4461-11e9-b327-0050568ebef5:l1/operations/16908292"
litigation.id
string
path
True
Litigation ID
id
string
path
True
Operation ID.
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
13763280
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.
13763378
SnapLock legal-hold operation for this operation ID does not exist
14090346
Internal Error. Wait a few minutes, then try the command again
14090541
A completed or failed operation cannot be aborted
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
