Cancel the ongoing legal-hold operation
DELETE /storage/snaplock/litigations/{litigation.id}/operations/{id}
Introduced In: 9.7
Aborts the ongoing legal-hold operation. An abort does not rollback any changes already made. You must re-run begin or end for cleanup.
Related ONTAP commands
snaplock legal-hold abort
Example
DELETE "/api/storage/snaplock/litigations/f8a67b60-4461-11e9-b327-0050568ebef5:l1/operations/16908292"
Name | Type | In | Required | Description |
litigation.id |
string |
path |
True |
Litigation ID |
id |
string |
path |
True |
Operation ID. |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code | Description |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
14090541 |
A completed or failed operation cannot be aborted |
Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
