Cancel the ongoing legal-hold operation
Stops an ongoing legal-hold operation without rolling back any changes that have already been made. This is useful when you need to terminate the operation early but plan to handle cleanup separately.
HTTP method and endpoint
DELETE /storage/snaplock/litigations/{litigation.id}/operations/{id}
Introduced in
ONTAP 9.7
Usage notes
Aborts the ongoing legal-hold operation. An abort does not rollback any changes already made. You must re-run begin or end for cleanup.
Related ONTAP commands
snaplock legal-hold abort
Example
DELETE "/api/storage/snaplock/litigations/f8a67b60-4461-11e9-b327-0050568ebef5:l1/operations/16908292"
litigation.id |
string |
path |
True |
Litigation ID |
id |
string |
path |
True |
Operation ID. |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
13763280 |
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation. |
13763378 |
SnapLock legal-hold operation for this operation ID does not exist |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
14090541 |
A completed or failed operation cannot be aborted |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
