REST API reference
Delete an SVM peer relationship
Removes an SVM peer relationship when you no longer need the connection between storage virtual machines.
HTTP method and endpoint
DELETE /svm/peers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the SVM peer relationship.
  • vserver peer delete
Example
  1. Deletes an SVM peer relationship.
 DELETE "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
  1. Deletes an SVM peer relationship using force flag
 DELETE "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"force": "true"}'
Learn more
uuid
string
path
True
SVM peer relationship UUID
  • Introduced in: 9.7
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error codes Description
26345578
Internal error. Unable to retrieve local or peer SVM name.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
