Delete an SVM peer relationship
Deletes an SVM peer relationship when you no longer need the connection between the peer SVMs.
HTTP method and endpoint
DELETE /svm/peers/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver peer delete
Example
Deletes an SVM peer relationship.
DELETE "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
Learn more
uuid |
string |
path |
True |
SVM peer relationship UUID
return_timeout |
integer |
query |
False |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345578 |
Internal error. Unable to retrieve local or peer SVM name. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
