Delete an SVM peer relationship
Deletes an SVM peer relationship to remove the connection between two storage virtual machines. Use this operation when you no longer need the peer relationship for data access or replication.
HTTP method and endpoint
DELETE /svm/peers/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver peer delete
Example
Deletes an SVM peer relationship.
DELETE "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
Deletes an SVM peer relationship using force flag
DELETE "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"force": "true"}'
Learn more
uuid |
string |
path |
True |
SVM peer relationship UUID
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345578 |
Internal error. Unable to retrieve local or peer SVM name. |
9895956 |
Cannot delete an SVM that is part of an SVM peer or transition peer relationship. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
