REST API reference
Delete an SVM peer relationship
DELETE /svm/peers/{uuid}
Introduced In: 9.6
Deletes the SVM peer relationship.
  • vserver peer delete
Example
  1. Deletes an SVM peer relationship.
 DELETE "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9"
  1. Deletes an SVM peer relationship using force flag
 DELETE "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"force": "true"}'
Learn more
uuid
string
path
True
SVM peer relationship UUID
  • Introduced in: 9.7
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error codes Description
26345578
Internal error. Unable to retrieve local or peer SVM name.
9895956
Cannot delete an SVM that is part of an SVM peer or transition peer relationship.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
