Retrieve NIS domain configurations of all SVMs
Accesses NIS domain configurations for all SVMs, which helps in identifying the successfully bound NIS servers. This is useful for diagnosing lookup and authentication issues when no servers are bound.
HTTP method and endpoint
GET /name-services/nis
Introduced in
ONTAP 9.6
Usage notes
Retrieves NIS domain configurations of all the SVMs. The bound_servers field indicates the successfully bound NIS servers. Lookups and authentications fail if there are no bound servers.
Related ONTAP commands
vserver services name-service nis-domain show -
vserver services name-service nis-domain show-bound -
vserver services name-service nis-domain show-bound-debug
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
domain |
string |
query |
False |
Filter by domain
servers |
string |
query |
False |
Filter by servers
bound_servers |
string |
query |
False |
Filter by bound_servers
binding_details.server |
string |
query |
False |
Filter by binding_details.server
binding_details.status.message |
string |
query |
False |
Filter by binding_details.status.message
binding_details.status.code |
string |
query |
False |
Filter by binding_details.status.code
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of NIS domain records. |
records |
array[nis_service] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"binding_details": [
"server": "string",
"status": {
"code": "string",
"message": "string"
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
binding_status
code |
string |
Code corresponding to the server's binding status. |
message |
string |
Detailed description of the server's binding status. |
binding_details
server |
string |
Hostname/IP address of the NIS server in the domain. |
status |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
nis_service
_links |
binding_details |
array[binding_details] |
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field. |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
