REST API reference
Retrieve NIS domain configurations of all SVMs
Retrieves NIS domain configurations for all SVMs to understand the successfully bound NIS servers. This is crucial for diagnosing issues with lookups and authentications in the absence of bound servers.
HTTP method and endpoint
GET /name-services/nis
Introduced in
ONTAP 9.6
Usage notes
Retrieves NIS domain configurations of all the SVMs. The bound_servers field indicates the successfully bound NIS servers. Lookups and authentications fail if there are no bound servers.
  • vserver services name-service nis-domain show
  • vserver services name-service nis-domain show-bound
  • vserver services name-service nis-domain show-bound-debug
bound_servers
string
query
False
Filter by bound_servers
  • maxLength: 255
  • minLength: 1
  • Introduced in: 9.7
domain
string
query
False
Filter by domain
  • maxLength: 64
  • minLength: 1
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
servers
string
query
False
Filter by servers
  • maxLength: 255
  • minLength: 1
binding_details.status.code
string
query
False
Filter by binding_details.status.code
  • Introduced in: 9.11
binding_details.status.message
string
query
False
Filter by binding_details.status.message
binding_details.server
string
query
False
Filter by binding_details.server
  • maxLength: 255
  • minLength: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of NIS domain records.
records
array[nis_service]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "binding_details": [
          "server": "string",
          "status": {
            "code": "string",
            "message": "string"
      "bound_servers": [
        "string"
      "domain": "domainA.example.com",
      "servers": [
        "10.10.10.10",
        "example.com"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
binding_status
code
string
Code corresponding to the server's binding status.
message
string
Detailed description of the server's binding status.
binding_details
server
string
Hostname/IP address of the NIS server in the domain.
status
binding_status
svm
_links
_links
name
string
uuid
string
nis_service
_links
_links
binding_details
array[binding_details]
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field.
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
