Retrieve NIS domain configurations of all SVMs
Accesses the NIS domain configurations for all SVMs to understand the network information service setup. This helps in determining the status of bound NIS servers and identifying potential issues with lookups and authentications.
HTTP method and endpoint
GET /name-services/nis
Introduced in
ONTAP 9.6
Usage notes
Retrieves NIS domain configurations of all the SVMs. The bound_servers field indicates the successfully bound NIS servers. Lookups and authentications fail if there are no bound servers.
Related ONTAP commands
vserver services name-service nis-domain show -
vserver services name-service nis-domain show-bound
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
servers |
string |
query |
False |
Filter by servers
domain |
string |
query |
False |
Filter by domain
bound_servers |
string |
query |
False |
Filter by bound_servers
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of NIS domain records. |
records |
array[nis_service] |
"next": {
"href": "/api/resourcelink"
"records": [
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
nis_service
_links |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
