Retrieve NIS domain configurations of all SVMs
Retrieves NIS domain configurations for all SVMs, which helps you understand the successful binding status of NIS servers.
HTTP method and endpoint
GET /name-services/nis
Introduced in
ONTAP 9.6
Usage notes
Retrieves NIS domain configurations of all the SVMs. The bound_servers field indicates the successfully bound NIS servers. Lookups and authentications fail if there are no bound servers.
Related ONTAP commands
vserver services name-service nis-domain show -
vserver services name-service nis-domain show-bound -
vserver services name-service nis-domain show-bound-debug
Learn more
servers |
string |
query |
False |
Filter by servers
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
domain |
string |
query |
False |
Filter by domain
binding_details.server |
string |
query |
False |
Filter by binding_details.server
binding_details.status.message |
string |
query |
False |
Filter by binding_details.status.message
binding_details.status.code |
string |
query |
False |
Filter by binding_details.status.code
bound_servers |
string |
query |
False |
Filter by bound_servers
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of NIS domain records. |
records |
array[nis_service] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"binding_details": [
"server": "string",
"status": {
"code": "string",
"message": "string"
"bound_servers": [
"string"
"domain": "domainA.example.com",
"servers": [
"10.10.10.10",
"example.com"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
binding_status
code |
string |
Code corresponding to the server's binding status. |
message |
string |
Detailed description of the server's binding status. |
binding_details
server |
string |
Hostname/IP address of the NIS server in the domain. |
status |
svm
_links |
name |
string |
uuid |
string |
nis_service
_links |
binding_details |
array[binding_details] |
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field. |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
