Retrieve shadow copy sets
Retrieves shadow copy sets to view existing backup copies of your data, which can be useful for data recovery or archival purposes.
HTTP method and endpoint
GET /protocols/cifs/shadowcopy-sets
Introduced in
ONTAP 9.11
Usage notes
Retrieves Shadowcopy Sets.
Related ONTAP commands
vserver cifs shadowcopy show-sets
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
keep_snapshots |
boolean |
query |
False |
Filter by keep_snapshots |
uuid |
string |
query |
False |
Filter by uuid |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[shadowcopy_set] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"keep_snapshots": "",
"svm": {
"name": "svm1",
"uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
shadowcopy_set
keep_snapshots |
boolean |
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation. |
svm |
uuid |
string |
The universally-unique identifier of the storage's shadow copy set. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
