Retrieve shadow copy sets
Retrieves shadow copy sets to view the available versions of files and directories in a volume for data recovery or access purposes.
HTTP method and endpoint
GET /protocols/cifs/shadowcopy-sets
Introduced in
ONTAP 9.11
Usage notes
Retrieves Shadowcopy Sets.
Related ONTAP commands
vserver cifs shadowcopy show-sets
Learn more
uuid |
string |
query |
False |
Filter by uuid |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
keep_snapshots |
boolean |
query |
False |
Filter by keep_snapshots |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[shadowcopy_set] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"keep_snapshots": 1,
"svm": {
"name": "svm1",
"uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
shadowcopy_set
keep_snapshots |
boolean |
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation. |
svm |
uuid |
string |
The universally-unique identifier of the storage's shadow copy set. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
