REST API reference
Retrieve shadow copy sets
Retrieves shadow copy sets to view the available shadow copies of your data, which can be useful for data recovery and versioning tasks.
HTTP method and endpoint
GET /protocols/cifs/shadowcopy-sets
Introduced in
ONTAP 9.11
Usage notes
Retrieves Shadowcopy Sets.
  • vserver cifs shadowcopy show-sets
keep_snapshots
boolean
query
False
Filter by keep_snapshots
uuid
string
query
False
Filter by uuid
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[shadowcopy_set]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "keep_snapshots": "",
      "svm": {
        "name": "svm1",
      "uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
shadowcopy_set
keep_snapshots
boolean
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy set.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
