REST API reference
Retrieve shadow copy sets
GET /protocols/cifs/shadowcopy-sets
Introduced In: 9.11
Retrieves Shadowcopy Sets.
  • vserver cifs shadowcopy show-sets
uuid
string
query
False
Filter by uuid
keep_snapshots
boolean
query
False
Filter by keep_snapshots
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[shadowcopy_set]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "keep_snapshots": 1,
      "svm": {
        "name": "svm1",
      "uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
shadowcopy_set
keep_snapshots
boolean
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy set.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
