REST API reference
Retrieve the current NDMP mode
Retrieves the current NDMP mode to understand the present configuration of NDMP services in your environment. This information can help you manage and modify NDMP operations as needed.
HTTP method and endpoint
GET /protocols/ndmp
Introduced in
ONTAP 9.7
  • system services ndmp node-scope-mode status
Learn more
mode
string
query
False
Filter by mode
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
mode
string
Indicates whether NDMP is in node-scoped or SVM-scoped mode.
      "href": "/api/resourcelink"
  "mode": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
