REST API reference
Retrieves the current ndmp mode
learn more
  • [doc /protocols/ndmp](#docs-ndmp-protocols_ndmp)
GET /protocols/ndmp
Introduced In: 9.7
Retrieves the current NDMP mode.
  • system services ndmp node-scope-mode status
Learn more
mode
string
query
False
Filter by mode
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
mode
string
Indicates whether NDMP is in node-scoped or SVM-scoped mode.
      "href": "/api/resourcelink"
  "mode": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
