REST API reference
Retrieve the current NDMP mode
Retrieves the current NDMP mode to determine the operational mode for NDMP services on your ONTAP system.
HTTP method and endpoint
GET /protocols/ndmp
Introduced in
ONTAP 9.7
  • system services ndmp node-scope-mode status
Learn more
mode
string
query
False
Filter by mode
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
mode
string
Indicates whether NDMP is in node-scoped or SVM-scoped mode.
      "href": "/api/resourcelink"
  "mode": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
