Retrieve the current NDMP mode
Retrieves the current NDMP mode to understand the data management protocol settings in your ONTAP system.
HTTP method and endpoint
GET /protocols/ndmp
Introduced in
ONTAP 9.7
Related ONTAP commands
system services ndmp node-scope-mode status
Learn more
mode |
string |
query |
False |
Filter by mode |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
mode |
string |
Indicates whether NDMP is in node-scoped or SVM-scoped mode. |
"href": "/api/resourcelink"
"mode": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
68812807 |
NDMP node-scope mode is not supported on this platform. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
