Initiate a switchover, heal, or switchback operation
Initiates a switchover, heal, or switchback operation to manage the state of MetroCluster configurations. Use this endpoint when orchestrating changes in MetroCluster roles for maintenance or recovery purposes.
HTTP method and endpoint
PATCH /cluster/metrocluster
Introduced in
ONTAP 9.8
Usage notes
Initiates a switchover, heal or switchback operation.
Related ONTAP commands * metrocluster switchover * metrocluster switchback * metrocluster heal
action |
string |
query |
False |
Action to perform on the MetroCluster.
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
