REST API reference
Initiate a switchover, heal, or switchback operation
Initiates a switchover or switchback operation to manage data availability and disaster recovery in a MetroCluster configuration.
HTTP method and endpoint
PATCH /cluster/metrocluster
Introduced in
ONTAP 9.8
action
string
query
False
Action to perform on the MetroCluster.
  • enum: ["switchover", "negotiated_switchover", "negotiated_switchover_simulate", "switchback", "switchback_simulate"]
return_timeout
integer
query
False
Timeout in seconds for the call.
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
