Initiate a switchover, heal, or switchback operation
Initiates a switchover, heal, or switchback operation to manage MetroCluster configurations efficiently. These operations are crucial for maintaining high availability and disaster recovery scenarios.
HTTP method and endpoint
PATCH /cluster/metrocluster
Introduced in
ONTAP 9.8
Usage notes
Initiates a switchover, heal or switchback operation.
Related ONTAP commands
metrocluster switchover -
metrocluster switchback -
metrocluster heal
action |
string |
query |
False |
Action to perform on the MetroCluster.
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
configuration_type |
string |
Displays the MetroCluster configuration type. |
encryption_enabled |
boolean |
Indicates if the encryption for NVLog and storage traffic is enabled. |
local |
remote |
Example request
"configuration_type": "string",
"local": {
"automatic_uso_failure_domain": "string",
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"mode": "string"
"remote": {
"cluster": {
"name": "cluster1",
"mode": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2424873 |
Failed to validate the node and cluster components before the "action" operation. |
2425138 |
Switchover cannot be performed in the current DR mode. Run "metrocluster show" to view the DR mode of the local cluster, and run "switchover" only in one of the following situations: 1. The DR mode of the local cluster is "normal". 2. The DR mode of the local cluster is "partial-switchover". |
2425333 |
Heal DR data aggregates cannot be performed in the current DR mode. Run "metrocluster show" and "metrocluster node show" to view the DR mode of the local cluster and the DR mode of the local nodes respectively, and run "heal aggregates" only in one of the following situations: 1. The DR mode of the local cluster is "switchover", and the DR mode of all local nodes is "switchover completed". 2. The DR mode of at least one local node is "heal aggrs failed". |
2425335 |
Heal DR root aggregates cannot be performed in the current DR mode. Run "metrocluster node show" to view the DR mode of the local nodes, and run "heal root-aggregates" only in one of the following situations: 1. The DR mode of all local nodes is "heal aggrs completed". 2. The DR mode of at least one local node is "heal roots failed". |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2427558 |
This MetroCluster operation cannot be run because another "action" operation is currently in progress. Run "metrocluster operation history show -job-id id -instance" to view the status of the currently running operation. |
href |
string |
self_link
_links
node
Local node of the DR Group.
name |
string |
uuid |
string |
partner
Partner node of the DR Group.
name |
string |
uuid |
string |
dr_pairs
node |
Local node of the DR Group. |
partner |
Partner node of the DR Group. |
cluster
name |
string |
uuid |
string |
local
automatic_uso_failure_domain |
string |
This parameter specifies the configuration of automatic switchover. The valid values for the parameter are ':' cluster':' triggers an unplanned switchover if all nodes in a DR cluster are down. dr_group':' triggers an unplanned switchover if both nodes of a DR group are down. disabled':' automatic switchover is disabled. If the cluster is not reachable due to errors, the parameter value will be set to not_reachable. This value is read only. If the cluster configuration is unknown, the parameter value will be set to unknown and the value is read only. |
cluster |
configuration_state |
string |
Indicates the state of the local cluster configuration. |
mode |
string |
Specifies the mode of operation of the local cluster. |
partner_cluster_reachable |
boolean |
Specifies whether the partner cluster is reachable from the local cluster. |
periodic_check_enabled |
boolean |
Indicates whether or not a periodic check is enabled on the local cluster. |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
l3_config
ipv4_interface |
Object to setup an interface along with its default router. |
node
Node information
name |
string |
uuid |
string |
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config |
name |
string |
Port name |
node |
Node information |
uuid |
string |
Port UUID |
vlan_id |
integer |
VLAN ID |
dr_group
DR group reference.
id |
integer |
DR Group ID |
peer_cluster
The peer cluster that the mediator service is used for.
name |
string |
uuid |
string |
mediator
Mediator information
dr_group |
DR group reference. |
peer_mediator_connectivity |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
partner_cluster
Partner cluster information.
name |
string |
uuid |
string |
remote
string |
cluster |
string |
Indicates the state of the remote cluster configuration. |
mode |
string |
Specifies the mode of operation of the remote cluster. |
boolean |
Indicates whether or not a periodic check is enabled on the remote cluster. |
metrocluster
Holds MetroCluster status and configuration parameters for the local and remote clusters. REST: /api/cluster/metrocluster
string |
boolean |
local |
remote |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
