REST API reference
Initiate a switchover, heal, or switchback operation
Initiates a switchover, heal, or switchback operation to manage the state of your MetroCluster configuration effectively. Use this operation to transition between different cluster states as needed.
HTTP method and endpoint
PATCH /cluster/metrocluster
Introduced in
ONTAP 9.8
Usage notes
Initiates a switchover, heal or switchback operation.
action
string
query
False
Action to perform on the MetroCluster.
  • enum: ["switchover", "negotiated_switchover", "negotiated_switchover_simulate", "switchback", "switchback_simulate", "heal_aggregates", "heal_root_aggregates"]
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
configuration_type
string
Displays the MetroCluster configuration type.
local
local
remote
remote
Example request
  "configuration_type": "string",
  "local": {
    "automatic_uso_failure_domain": "string",
    "cluster": {
      "name": "cluster1",
    "configuration_state": "string",
    "mode": "string"
  "remote": {
    "cluster": {
      "name": "cluster1",
    "mode": "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
2424873
Failed to validate the node and cluster components before the "action" operation.
2425138
Switchover cannot be performed in the current DR mode. Run "metrocluster show" to view the DR mode of the local cluster, and run "switchover" only in one of the following situations: 1. The DR mode of the local cluster is "normal". 2. The DR mode of the local cluster is "partial-switchover".
2425333
Heal DR data aggregates cannot be performed in the current DR mode. Run "metrocluster show" and "metrocluster node show" to view the DR mode of the local cluster and the DR mode of the local nodes respectively, and run "heal aggregates" only in one of the following situations: 1. The DR mode of the local cluster is "switchover", and the DR mode of all local nodes is "switchover completed". 2. The DR mode of at least one local node is "heal aggrs failed".
2425335
Heal DR root aggregates cannot be performed in the current DR mode. Run "metrocluster node show" to view the DR mode of the local nodes, and run "heal root-aggregates" only in one of the following situations: 1. The DR mode of all local nodes is "heal aggrs completed". 2. The DR mode of at least one local node is "heal roots failed".
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2427558
This MetroCluster operation cannot be run because another "action" operation is currently in progress. Run "metrocluster operation history show -job-id id -instance" to view the status of the currently running operation.
string
node
Local node of the DR Group.
name
string
uuid
string
partner
Partner node of the DR Group.
name
string
uuid
string
dr_pairs
node
node
partner
partner
cluster
name
string
uuid
string
local
string
This parameter specifies the configuration of automatic switchover. The valid values for the parameter are ':' cluster':' triggers an unplanned switchover if all nodes in a DR cluster are down. dr_group':' triggers an unplanned switchover if both nodes of a DR group are down. disabled':' automatic switchover is disabled. If the cluster is not reachable due to errors, the parameter value will be set to not_reachable. This value is read only. If the cluster configuration is unknown, the parameter value will be set to unknown and the value is read only.
cluster
cluster
configuration_state
string
Indicates the state of the local cluster configuration.
mode
string
Specifies the mode of operation of the local cluster.
partner_cluster_reachable
boolean
Specifies whether the partner cluster is reachable from the local cluster.
periodic_check_enabled
boolean
Indicates whether or not a periodic check is enabled on the local cluster.
ipv4_interface
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
l3_config
ipv4_interface
ipv4_interface
node
Node information
name
string
uuid
string
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config
l3_config
name
string
Port name
node
node
Node information
uuid
string
Port UUID
vlan_id
integer
VLAN ID
dr_group
DR group reference.
id
integer
DR Group ID
peer_cluster
The peer cluster that the mediator service is used for.
name
string
uuid
string
mediator
Mediator information
dr_group
dr_group
DR group reference.
peer_mediator_connectivity
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown.
reachable
boolean
Indicates the connectivity status of the mediator.
uuid
string
The unique identifier for the mediator service.
partner_cluster
Partner cluster information.
name
string
uuid
string
remote
string
cluster
cluster
configuration_state
string
Indicates the state of the remote cluster configuration.
mode
string
Specifies the mode of operation of the remote cluster.
boolean
Indicates whether or not a periodic check is enabled on the remote cluster.
metrocluster
Holds MetroCluster status and configuration parameters for the local and remote clusters. REST: /api/cluster/metrocluster
configuration_type
string
local
local
remote
remote
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
