REST API reference
Update a shadow copy set
Updates a shadow copy set to modify its properties or configuration. This operation is useful for maintaining consistency across shadow copies or adapting to changes in your data management strategy.
HTTP method and endpoint
PATCH /protocols/cifs/shadowcopy-sets/{uuid}
Introduced in
ONTAP 9.11
Usage notes
Updates a Shadowcopy set
uuid
string
path
True
Storage shadowcopy set ID.
Request Body
Name Type Description
keep_snapshots
boolean
Request the storage system to keep the snapshot copies taken as a part of the shadow copy set creation.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy set.
Example request
  "keep_snapshots": "",
  "svm": {
    "name": "svm1",
  "uuid": "f8328660-00e6-11e6-80d9-005056bd65a9"
Status: 200, Ok
Status: Default, Error
string
svm
name
string
The name of the SVM.
uuid
string
shadowcopy_set
keep_snapshots
boolean
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
